Alex Posted February 10, 2012 Share Posted February 10, 2012 (edited) Για ριξτε μια ματια στο παρακατω λινκ... http://www.polarteam.net/en/65-polar-fis-advanced.html http://www.google.gr/search?q=Polar+FIS%2B+Advanced+(PF03) Κανει για TFSI-TSI και βγαζει στην κεντρικη οθονη τις παρακατω λειτουργιες! - Real speed (readed from ECU) - Oil temperature (°C / °F) - Coolant temperature (°C / °F) - Outdoor temperature (°C / °F) - Admision temperature (°C / °F) - Turbo pressure - RPM motor - Voltage of the battery. - Fuel remaining (Litres / Gallons) - Atmospheric pressure - Pressure fuel pump - Motor load. - Ambient Temperature (engine ECU) - Coolant temperature engine output. - Coolant temperature leaving the radiator. - Mass air flow - Admision pressure - Sensor 1 throttle pedal - Sensor 2 throttle pedal - Sensor 1 throttle valve - Sensor 2 throttle valve - Horse power used (CV) - Oil level - Minimum oil level - Brake master cylinder pressure - Pressure in the fuel rail - Torque used NM - Injection timming - Injection quantity - Injection angle - Injection start - TV Free function Και δειτε τις φωτο πως εμφανιζετε στο καντραν! Edited February 10, 2012 by Alex 3 Quote Link to comment Share on other sites More sharing options...
costas7000 Posted February 10, 2012 Share Posted February 10, 2012 πως το κανουμε αυτο???? Quote Link to comment Share on other sites More sharing options...
Alex Posted February 10, 2012 Author Share Posted February 10, 2012 (edited) πως το κανουμε αυτο???? Δες το λινκ γιατι ξεχασα να το βαλω Θα το βαλω δεν υπαρχει περιπτωση! Μεχρι και θερμοκρασια καυσαεριων εχει! Edited February 10, 2012 by Alex Quote Link to comment Share on other sites More sharing options...
kostas_7 Posted February 10, 2012 Share Posted February 10, 2012 Πολύ καλό εεεεε.....Δηλαδή το χεις μόνιμα στη φύσα; Quote Link to comment Share on other sites More sharing options...
Alex Posted February 10, 2012 Author Share Posted February 10, 2012 Πολύ καλό εεεεε.....Δηλαδή το χεις μόνιμα στη φύσα; Μονιμα Κωστα και ουτε μπαρομετρα ουτε πυρομετρα! Θα βλεπεις πιεση βεζνινης της αντλιας μεχρι και maf και γενικα οτi δειχνει το vag-com τα παντα ολα! Quote Link to comment Share on other sites More sharing options...
kalatzos Posted February 10, 2012 Share Posted February 10, 2012 Έχει και αυτό http://www.kufatec.de/shop/product_info.php/language/en/info/p1329_c320_E-MFA-Anzeige-von-Ladedruck--Oeltemperatur-uvm--im-Tacho.html αλλά απ'ότι λέει δεν κάνει για Audi. Quote Link to comment Share on other sites More sharing options...
popi-cupra Posted February 10, 2012 Share Posted February 10, 2012 έχει τα πάντα! πολύ καλό φαίνεται!!!! http://www.youtube.com/watch?v=k_0-YotIiT0&feature=related η mfd όμως δεν σε αφήνει να μπαίνεις στα function, όταν το αμάξι είναι εν κινήσει, οπότε μάλλον θα παραμένει σε αυτή την εικόνα, όταν είσαι καθοδόν το έχει βάλει κανένας γνωστός σας? έχει καλό value for money για αυτά που παρέχει! το περίεργο είναι ότι ενώ γράφει ότι είναι για vw, skoda, seat, δεν γράφει τίποτα για audi :P Quote Link to comment Share on other sites More sharing options...
Alex Posted February 10, 2012 Author Share Posted February 10, 2012 έχει καλό value for money για αυτά που παρέχει! το περίεργο είναι ότι ενώ γράφει ότι είναι για vw, skoda, seat, δεν γράφει τίποτα για audi :P Νομιζεις καλο μου παιδι Επικοινωνησα με τον εν λογω επαγγελματια (με πμ) που τα εχει εδω...και μου ειπε κανει και για audi...τωρα για την λειτουργια αναμενω αποτελεσματα μολις γινει τοποθετηση εδω Αθηνα...στην Κυπρο ειναι ηδη υποδοκιμη και αναμενουμε! Οποτε ειναι σημαντικο αυτο που λες οτι ενκινηση δεν δουλευει Quote Link to comment Share on other sites More sharing options...
mariosA4 Posted February 10, 2012 Share Posted February 10, 2012 Αλέξη δεν ρωτάς αν δουλεύει και στα Α4 Β6? Quote Link to comment Share on other sites More sharing options...
kenzo Posted February 10, 2012 Share Posted February 10, 2012 Μπραβο Αλεξ ! +1 Quote Link to comment Share on other sites More sharing options...
Alex Posted February 10, 2012 Author Share Posted February 10, 2012 Αλέξη δεν ρωτάς αν δουλεύει και στα Α4 Β6? Quote Link to comment Share on other sites More sharing options...
remwin2 Posted February 10, 2012 Share Posted February 10, 2012 Με τοσες λειτουργιες σιγουρα ειναι ενδιαφερον. Βεβαια στο boost ειναι λιγο ζητημα γιατι δεν μπορεις να κοιτας εκει τι σηκωνεις,Εδω στα 60αρια οργανακια και κοιτας κλεφτα και παλι δεν προλαβαινεις να δεις απλα κοιτας μετα το peak. Να μην δουλευει εν κινησει δεν το νομιζω αλλιως προσωπικη μου αποψη ειναι αχρηστο. Πολυ χρησιμο βρισκω πυρομετρο,πιεση αντλιας,μπεκ,φορτια.Αλλα αυτα πως θα προλαβαινεις να τα τσεκαρεις ολα εν κινησει?Εκτος αν εχεις μια τιμη στο μυαλο σου και πας στο περιπου...Γιατι αν δεν τα δεις τα νουμερα σε μια σειρα με στροφες κινητηρα και να συγκρινεις δεν βγαινει ευκολα συμπερασμα.... Quote Link to comment Share on other sites More sharing options...
Kavouras Posted February 10, 2012 Share Posted February 10, 2012 Με τοσες λειτουργιες σιγουρα ειναι ενδιαφερον. Βεβαια στο boost ειναι λιγο ζητημα γιατι δεν μπορεις να κοιτας εκει τι σηκωνεις,Εδω στα 60αρια οργανακια και κοιτας κλεφτα και παλι δεν προλαβαινεις να δεις απλα κοιτας μετα το peak. Να μην δουλευει εν κινησει δεν το νομιζω αλλιως προσωπικη μου αποψη ειναι αχρηστο. Πολυ χρησιμο βρισκω πυρομετρο,πιεση αντλιας,μπεκ,φορτια.Αλλα αυτα πως θα προλαβαινεις να τα τσεκαρεις ολα εν κινησει?Εκτος αν εχεις μια τιμη στο μυαλο σου και πας στο περιπου...Γιατι αν δεν τα δεις τα νουμερα σε μια σειρα με στροφες κινητηρα και να συγκρινεις δεν βγαινει ευκολα συμπερασμα.... μάλλον εννοεί ότι δεν μπορείς να μπεις στις ρυθμίσεις και να το "πειράζεις" εν κινήσει (να θες να αλλάξεις τι θα σου δείχνει δηλαδή). Το ίδιο συμβαίνει σε πολλά συστήματα για λόγους ασφαλείας (για να μην "παίζεις" με τις ρυθμίσεις και ταυτόχρονα οδηγείς). Quote Link to comment Share on other sites More sharing options...
ianos Posted February 10, 2012 Share Posted February 10, 2012 (edited) Μπράβο Alex! +1 και από μένα!! Να κοιτάξουμε αν είμαστε αρκετοί οι ενδιαφερόμενοι μήπως πάμε για group buy??? Λογικά θα μπορεί να συνδεθεί με την οθόνη που έχουν τα B8 στο κέντρο της κονσόλας ή συνδέεται μόνο με την οθόνη που βρίσκεται στον πίνακα οργάνων?? Τί εννοεί ο ποιητής με το "TV Free function" Edited February 10, 2012 by ianos Quote Link to comment Share on other sites More sharing options...
Alex Posted February 10, 2012 Author Share Posted February 10, 2012 Να κοιτάξουμε αν είμαστε αρκετοί οι ενδιαφερόμενοι μήπως πάμε για group buy??? Στο μυαλο μου εισαι Quote Link to comment Share on other sites More sharing options...
popi-cupra Posted February 10, 2012 Share Posted February 10, 2012 Βεβαια στο boost ειναι λιγο ζητημα γιατι δεν μπορεις να κοιτας εκει τι σηκωνεις,Εδω στα 60αρια οργανακια και κοιτας κλεφτα και παλι δεν προλαβαινεις να δεις απλα κοιτας μετα το peak. στο greedy-profec b, κρατάει για 3 δευτερόλεπτα και αναβοσβήνει ΚΑΙ το στιγμιαίο Peak (και εννοείτε, έχει και μνήμη για το μέγιστο peak) Quote Link to comment Share on other sites More sharing options...
Mpekas Posted February 25, 2012 Share Posted February 25, 2012 Group Buy !!!!! Group Buy !!!!! Quote Link to comment Share on other sites More sharing options...
powergolf Posted February 26, 2012 Share Posted February 26, 2012 Quote Link to comment Share on other sites More sharing options...
georgio3gr Posted February 26, 2012 Share Posted February 26, 2012 Με Α4 Β6-Β7 δεν ειναι συμβατο; Quote Link to comment Share on other sites More sharing options...
Alex Posted February 27, 2012 Author Share Posted February 27, 2012 Σε διαφημηση που το ειδα σε ενα περιοδικο για το ιδιο...λεει οτι οι ενδειξεις ειναι σε πραγματικο χρονο! Και συνδεετε και με την οθονη MMI Τιμη απο 260! Εγω ειμαι μεσα για Group Buy! Quote Link to comment Share on other sites More sharing options...
Giannis20vt Posted February 27, 2012 Share Posted February 27, 2012 Απο οσο το ειχα ψαξει παλαιοτερα Γιωργο, δεν ειχα βρει για τα b6-b7 τετοιο γκατζετ. ΜΠορει και να υπάρχει ομως Quote Link to comment Share on other sites More sharing options...
Mpekas Posted February 27, 2012 Share Posted February 27, 2012 Σε διαφημηση που το ειδα σε ενα περιοδικο για το ιδιο...λεει οτι οι ενδειξεις ειναι σε πραγματικο χρονο! Και συνδεετε και με την οθονη MMI Τιμη απο 260! Εγω ειμαι μεσα για Group Buy! μήπως θέλει αντάπτορα?? Quote Link to comment Share on other sites More sharing options...
M@rios Posted February 27, 2012 Share Posted February 27, 2012 Σε διαφημηση που το ειδα σε ενα περιοδικο για το ιδιο...λεει οτι οι ενδειξεις ειναι σε πραγματικο χρονο! Και συνδεετε και με την οθονη MMI Τιμη απο 260! Εγω ειμαι μεσα για Group Buy! Σε μενα κανει; Quote Link to comment Share on other sites More sharing options...
Alex Posted February 27, 2012 Author Share Posted February 27, 2012 (edited) μήπως θέλει αντάπτορα?? Δεντο γνωριζω αυτο! Σε μενα κανει; Ναι αγαπητε Edited February 27, 2012 by Alex Quote Link to comment Share on other sites More sharing options...
M@rios Posted February 27, 2012 Share Posted February 27, 2012 Μέσα και εγω τοτενες... Quote Link to comment Share on other sites More sharing options...
