Αντε ρε φιλος καιρο ειχαμε να δουμε νεα σου και αρχισα να ανησυχω!!!
Μα δεν σταμάτησα ποτε την δουλειά....
Άπλα δεν κανω post......Εχω κάνει παρα πολυ δουλειά......Η μηχανή κλείνει τώρα...
Τελείωσα μαζί τις.....
:worthy: :worthy: :worthy:
υγ λεω τον μηχανισμο απο την κουκουλα να τον ξηλωσεις διοτι ειναι περιττο βαρος :g:
Σάρκα και οστά φιλαράκι :speak_cool: Άντε να ακούσουμε το μοτέρ να αναστενάξουμε όλοι μαζί..
και το καλύτερο για το τέλος......
Torsen mod....!!!! 80-20% για περισσότερο παιχνίδι...
να το στείλω με κούριερ? ,πόσο χρεώνεται κύριε την επισκευή με φπά?
150 euros τα πήρα.....ψήνεσαι? Η Stasis το xρεώνει 655 :)
Aπο stasis webpage
Audi Torsen Center Differential Upgrade
For Manual Transmissions Only
Tuning the center differential provides one of the most significant performance gains available to the Quattro owner. The standard torsen center differential in the S4 and A4 provides a 2:1 torque distribution capability. This enables the end of the car with traction (generally the rear) to deliver twice the torque being delivered by the least tractive end of the vehicle (generally the front). For high performance street cars, we recommend a bias ratio of 4:1. This is the same bias ratio that Audi has provided in the stock RS4 driveline.
Torsen Differentials deliver more torque to the wheels that have more traction. The STaSIS high bias torsen provides a dramatic improvement in negotiating a turn quickly and efficiently. Now your car can be 3 cars in one( front, all and rear wheel drive):
Hard braking leading into a turn
Car acts like a front wheel drive – torsen acts like an open differential when its not under power. Wheels turn independently and car control is improved.
Mid Corner, Throttle On
Car acts like an all wheel drive– torsen delivers equal amounts of power to front and rear wheels. This maximizes grip, allowing more power to be applied at this stage of a turn.
Corner Exit, Hard Acceleration
Car acts like a rear wheel drive car – front wheel slip is rediced because the torsen delivers up to 88% of the engine torque to the rear wheels where the most traction is.
Edited by The Dog
μη μου ανάβεις φωτιές μες το καλοκαίρι, άσε να βγάλουμε σαιζόν και έρχόμαστε πακέτο....
Ήταν...
Έγινε....
Edited by The Dog
  • 4 weeks later...
Φιλαρακι σαν να ειμαστε εκει κ σε στηριζουμε με φαι,ποτα,γυναικες κ οτιδηποτε χρειαζεσαι! :thumbsup: :thumbsup: :thumbsup:
Νομίζω θα αρχίσω και εγω project!! :brows::brows:
Είσαι για δέσιμο σκύλε :thumbsup:
Υ.Γ. ότι έχεις βάλει προφυλακτήρες, φώτα κλπ έίναι bolt on ?
  • 3 weeks later...
Εννοείται Σόκι, μα κάνεις κάτι ερωτήσεις βρε παιδί μου :new_lol::new_lol:
Doggie για πες κανα νέο, πως πάει το τούμπανο?
αύριο θα βγάλω pic..Oλα bolton εκτός απο 2-3 πράγματα
Edited by The Dog
Καλημερα ρε πανικο!!!Τι κανεις ρε παλικαρι και εσυ? Πως παει το θηριο?
Ερωτηση... Και το water-intercooler ειναι bolt-on:speak_cool: (πλακα κανω)...Ρε παλικαρι το δοχειο του παγου που θα το προσαρμοσεις?
Αντε μας ενημερωνεις για το τι κανεις στο καμαρι σου για να μαθαινουμε και εμεις καμια καλη πατεντα!!!:whistling:
Πρόσεξε καλά μην τολμήσεις να βάλεις μπροστά και να μην είμαι στο ακουστικό να ακούω τις μιζιές diablo.gif Θα κατέβω στο νησί και θα φας πολλές boxing.gif
  • 1 month later...
καιρό έχω να γράψω updates για το project....
Το μοτέρ& κιβώτιο έχουν επανατοποθετηθεί (για δεύτερη φορά)αφού μετά την πρώτη εγκατασταση κατάφερα να κόψω banjo bolt μέσα στην τουρμπίνα...
Τελικά όμως μου βγήκε σε κάλο γιατί ανακάλυψα ένα oil leak από μισομοιρασμενο o-ring λαδιου στην κοιλιά . Αντικαταστάθηκε με νεο.
Έκλεισε και ένα μεγάλο κεφάλαιο χθες. Έγινε ο πρώτος , μάλλον και ο τελευταίως, ελεχος στην home made πλεξούδα εγκεφάλου και όλα δείχνουν να δουλεύουν σωστά...Ευτυχώς ,γιατί την δουλεύω από τον Αύγουστο.
Μου μένει να τελειώσω την γραμμή επιστροφής καυσίμου και να αλλάξω μια σωλήνα του υδραυλικού εάν πότε μου την στείλει ο Αρίστος..
Έχε και έναν πυροσβεστήρα όταν πας να βάλεις μπροστά για καλό και για κακό.. :Party_fest39::new_lol::new_iloveyou:
:thumbsup::speak_cool::whoohoo:
Ααααα,και δεν ανοιξα το κιβωτιο ο χαζός να σε εκβιάσω,λαμόγιο,
εσυ και ο κολλητός... :ranting2::rocket:
(ΧΜΜΜ,προλαβαίνω να ακυρωσω την αποστολή :brows: )
Κατι πρεπει να κανεις με αυτους Πανικο... :smokeing:
Ναι κρατάνε το project με νύχια και με δόντια για να μην τελειώσει...μην τους περνά κατάλαβες?? :1115038523::whistling::boxing:
Εσύ μην και δεν πεταχτείς σαν τη .... Λέουρα..
ΥΣ και σβήσε το τσιγάρο μεγάλε.. πολύ μαγκιά θα ....
Ρε αντε κοιμησου... :Party_fest39:
